FergusonTO35
- 12:42 PM
- Jul 9, 2017
- Boonesborough, KY
Isn't Volvo Construction the descendant of Michigan, Clarke, and a few other old marques?
Volvo's pretty common around meView attachment 278864
I don’t make a habit of posting up a bunch of pictures, but here’s a list.
Excavators:
-Cat 345D L x2
-Cat 336E L
-Cat 330D L w/thumb
-Link-Belt 235X3
-Cat 315C L w/thumb
Dozers:
-Cat D8L
-Cat D8R
-Cat D7G
-Cat D7R
-Cat D6R
-Cat D5K
-Cat D5G
Loaders:
-Cat 963D
-Cat 963C
-Cat 953C x2
-Cat 950G
-Cat 928G
-Cat 924K
Backhoes:
-Case 590SM
-Case 590SLx2
-Case 580SM
-Case 580SLx2
Skid Steer/Misc
-Cat 287C XPS 2 speed
-Cat 299C XPS 2 speed
-Case 465 S3
-Case 440 S3
My Cat dealer (Boyd, formerly Whayne/Walker) and I have a great working relationship, although I may be heading for a different excavator brand when it’s time to replace the old 315, 330 and the two 345s. They all have a lot of hours on them and the latest Cat excavators we’ve had out have not been as impressive as some of their competition.
@Skeans1
Jared, I’m gonna warn you now-After reading my post- I get pedantic.
I’m trying out the Volvo, it’s a 290 sized boom on a 350 undercarriage with zero tail swing. The highway contractor we’re setting pipe and structures for has a Caterpillar machine (335F) that is the same class, and it seems like it has some more power than the Volvo, looking at both machines digging the same material, both with pin grabbers and equivalent size buckets. John Deere & Hitachi have a machine that shares everything but the engine and and a few hydraulic components, but it has more tail swing than the Volvo or the Cat. I’ve talked to one person that’s run both and they think the Deere is more stable and faster when multifunctioning but the Cat may have more digging power.
What I’ve found is that the 330 & 336 (350 size) machines I have generally have more reach than I need and don’t have much more power than the 290 size machines. If these reduced tail swing machines with that much reach are stable enough, I’ll probably get them as replacement for my 350 sized machines. I can’t see any downside to a reduced tail swing that does everything a similarly sized standard tail swing machine.
I would bet that big John Deere reduced tail swing would do fine running a processor, the hydraulic flow specs on that machine are impressive and it has three pumps. It uses the same front as the 290G, so the mounts should be the same as the 3154 & 3156 forestry machines. Even then, I don’t doubt somebody like Jason out of Pape’s Eugene branch could put mounts for a shovel front on one.
For the rest of them, that 315 sits a lot, I don’t think it’s going anywhere. I usually just see it go out on smaller site jobs or smaller diameter pipe construction. The 345s are production machines, they’ll run for 15,000 hours before I see serious problems and they’re sitting around 9500 each. You might have seen over on the other site where I bought that 349, but it was fairly disappointing and I was lucky enough to sell it. I’ve had a Deere 470G on demo since that was a better all-around machine and I think that’ll be my next purchase once I replace my 350 sized machines.
I’ve never been around Volvo myself but I can tell you this I will never own a Cat machine again the pissed me off pretty good. I’m sure either would run a head but for shovel logging or loading logs is a great place for a zero or reduced tail swing as long as there’s still vision behind you.
View attachment 296030 Been doing some deep trenching in nasty soils. The Deere is doing pretty good. It doesn’t have the lifting power my kitties do but it’s more stable. I miss woods road building.
Then I go to a job I’m a sub on and go to their (probably 10 acre) laydown yard and you get reminded that your big hoe isn’t really that big... This is what they’re using to run big drainage culverts. For a while this was the “small” excavator on site.
Ok if that’s the small excavator what was the big girl?
