Thumper88
- 9:07 AM
- Feb 28, 2020
- Harriman, TN
Very nice. Ive got a Dolmar 7900 Id love to find someone to build a wrap handle for it
No I totally skipped the in-between photos. I was going to take a pic after it was welded out before I painted it but I got caught up in the moment lol.Got any pictures of after you welded or in the middle of welding ?
If I had a bender that would bend that tight of a radius I wouldn't mind doing them. Wouldn't be nothing to it really.Nicely done i have a couple half wraps you could do up for me
I've come to the conclusion that, when I weld a stock handle, to lay a base weld down like I'm filling a larger hole in thin material, then let it cool a little for the second step of tacking, cool again for the welding.No I totally skipped the in-between photos. I was going to take a pic after it was welded out before I painted it but I got caught up in the moment lol.
It was tricky welding to the stock handle. That sucker is thin!
The tubing I used was probably 1/8" wall. Trying to get the heavier tube to puddle without liquidating the stock handle was fun. Had to weld colder than I like.
I've got the dynasty 210sd. Doesn't have quite the adjustability that the dx has nor will it do pulsed ac. Also has no way to adjust background current in DC pulse. So pulse is pretty much worthless.I've come to the conclusion that, when I weld a stock handle, to lay a base weld down like I'm filling a larger hole in thin material, then let it cool a little for the second step of tacking, cool again for the welding.
Then I got the Dynasty ..................... still looking forward to playing with some of the settings/parameters on it for handles. I'm hoping to eliminate the cooling down process entirely
The Synchrowave 350 is archaic compared to the Dynasty 400 ................. but its what I learned on.I've got the dynasty 210sd. Doesn't have quite the adjustability that the dx has .
I haven't done this before but I always figured if I was doing that I'd either buy/acquire a 2nd half wrap and cut that up, or I'd buy a 372 wrap and cannibalize that.If I had a bender that would bend that tight of a radius I wouldn't mind doing them. Wouldn't be nothing to it really.
The death by a thousand cuts method is pretty time consuming and would be cost prohibitive. Probably had three hours in them start to finish.
That would probably work better. You would already have to bends to work with. Make a few cuts and just have buttwelds to deal with.I haven't done this before but I always figured if I was doing that I'd either buy/acquire a 2nd half wrap and cut that up, or I'd buy a 372 wrap and cannibalize that.
