- 12:29 PM
- Feb 26, 2017
- Belleville, Ontario, Canada
I have owned a MIG welder for many years and there is one issue that I have never been able to completely deal with: Vision
There are many times where I simply cannot see my welding path. If my helmet is set dark enough so I can watch the puddle comfortably, then everything around the puddle is black. If I set the helmet to a brighter setting, then I can somewhat see the area next to the puddle, but when I stop welding my vision needs time to readjust to normal ambient light. This problem is worst if I have to do a quick weld on something. If I am doing a larger project, my eyes will adjust and my vision will become adjusted to watching the weld and I can see fine. One thing I do to remedy my vision problem is I try to set up a very bright light to illuminate whatever I am welding, and this helps immensely, but I am wondering what you guys who are much more experienced than me do to allow you to see your welding path without seeing blue dots when you are finished?
Chris
Chris
