Poleman
- 9:17 AM
- Jan 18, 2016
- Rapid City,S.D.
Part II of my carb modding today. The first one was of the NO JET ZAMA C3M aftermarket carbs.
I started messing with a Walbro HD 12 today abd got some promising results. I had to do extra tweeting on this also.
Drilled the jet out to .043 from .035-.037 and closed the hole at the end of the H needle again following the lead from the work on the other carb.
The saw started an ran and had a good Hi, but idle was bad and it was starving for fuel. ( Tested on same Dolmar). I couldn't get it to idle right without running out of fuel. Back in I went and put in a weaker needle spring. I did that to alter the pop off so the needle would open sooner. That seemed to do the trick as idle was good, good adjustability on L & H, sounded good reving and slinging oil all over my garage floor.
Again It will need to be tested in wood to see the real truth. I do feel it's promising though. I will want to experiment with other jet sizes to see if a larger dro)ed jet would have any effect on the idle without a spring mod.
I'm finding one thing out....each carb model reacts differently to saw type and brand. The carbs for the Dolmars are way more aggressive with larger jets than what the Huskys can run. It seems each saw has a demand to what will make it run good......and it's different just like saw brands.
Stay tuned......I will be updating this as I do more testing.
