oaky
- 9:44 PM
- Nov 18, 2018
- massachusetts
got this old 385xp going again. found out it needs a off switch and a new tank vent/connector fitted in (leaked gas). but it did run well. 150 psi compression rating..
but
seems to be making a lot chattering noise on the flywheel side of the saw. listened at the clutch side not as noisy as the flywheel side/top end. check for loose screws/anything hitting the flywheel..nothing.
no play on the bearings either side as far as i could tell, maybe i missed something inside, maybe to much clearance on the cylinder i sanded, piston slapping? dont know.
anyone have any videos of a saw running with piston slap?
or any other ideas would be helpful as well.
but
