Tillotson Welch Plug question
SteveinUT
Have gun - will travel
2:28 AM
Southern Utah
Is there something I am missing? These two welch plugs won't come out? Any tricks to getting them out of there? This is on a HS series Tillotson on my 266XP.
SteveinUT
2:28 AM
Southern Utah
Thanks! That was my guess but I didn't want to eff stuff up!
CoreyB
3:28 AM
South east iowa
If they are in that we'll is there any need to change them? Just curious.
David Young
Safety First !!!!!!
4:28 AM
vt
Randy,
you could have had him
all you have to do is shake the carb real hard.
I have problems getting them to seal up when new.
67L36Driver
3:28 AM
In the off chance some trash made its way to the idle bleed ports.
I have not found a reason to R&R the plugs but the next one may prove to be the exception.[emoji57]
SteveinUT
2:28 AM
Southern Utah
They plugs came with the kit, along with a small screen for under one of them, so I pulled them and replaced them (had to replace them after popping the hole in each). Tried shaking the carb hard, but they wouldn't budge. Anyway, the thing is back together and should be good. I am glad I went through it, because the carb only had the reeds and diaphragm in the top and bottom. No gaskets. So, I double checked the carb exploded view and sure enough, there was supposed to be gaskets on the top and bottom of the carb as well. I thought it was odd that there wasn't gaskets. I put the carb back on the cylinder, but I won't have a chance to test it until the "new" tank gets here.
My *pretty boy also found that the muffler screen was almost completely plugged as well. So, that probably explains why the saw had almost no power regardless of my attempts to tune it. Anyway, I ordered one of the cheap Hutzl mufflers for it. Didn't need to, but the OEM was pretty dented and rusted, so I said screw it. Once I get all this stuff on it, hopefully it'll be a runner. It's a saw I'm considering sending to the "Mastermind" next time he has his books open...
Redfin
Meh...
4:28 AM
Central Pa
I have read to replace these if you see they are leaking. How can one tell if this is the case?
SteveinUT
2:28 AM
Southern Utah
Hey, I know what I was going to ask ya'll! Were the replacement plugs supposed to be put in with the dome going IN to the hole, or facing OUT of the hole? The exploded view was worthless on this. When I tore it down, one was up and one was down. I put them in with the domes facing OUT.
backhoelover
SERVICE MANUAL MASTER
4:28 AM
lincolnton nc
how to test leaking welch plugs
  • CRB 105 Service tools-d09aa59b55c68eb6595232374aa4304e.pdf
Genius
First member of ASlite to receive a infraction
4:28 AM
Uncle Willys basement
The dome facing out, then you knock the dome in to seal them.
SteveinUT
2:28 AM
Southern Utah
Thanks Genius! I'm going to open the bottom back up, then. I put them in facing out, but I didn't seat them. Just use a brass punch and give them a tap?
David Young
Safety First !!!!!!
4:28 AM
vt
Steve the installation is what I struggle with.
Did you shake up and down or side to side?
Genius
4:28 AM
Yes, that should work.
Some guys recommend putting some sort of sealer (nail polish) on the edge before you seat the plug. I have never done this, all the plugs i have installed have seated with no sealant.
