- 9:27 PM
- Jan 26, 2016
- South west UK
Are some Parts available then Andrew ?......New trigger unit ?Had this from eBay a few weeks ago buyer said it pulls over but won't start and couldn't see exactly which model it was from the poor photos
But anyway got it back and it's a 114 and just as I thought no spark typical fault with this model so straight in and swap out the trigger unit drain the tank , put on a new bar and chain little tweet up with the screwdriver and a smooth running 50cc saw this model is not a saw too be overlooked they run strong not too heavy
But I've put it on eBay it will go towards the cs-1201 fund
The SD 114 used a 2 piece transistor ignition, that has been NLA for ages here in the US. But You can snip the wires from the trigger under the flywheel or remove the trigger and replace the coil with a 1 piece coil from the 116si,120si,PS6000,PS6800 series saws. The flywheel had the same timing so no change required there. That saw is circa 1979-1980 due to the offset chain brake lever design. And it is wearing the European spec Muffler that had a awesome note. The issue that series had was the Tilly HK series carbs that were problematic due to the plastic module body that held the metering valve and circuits. There was a walbro replacement that worked much better. That age SD 114 is the saw that got us hooked on SD back in 79' and here we are years later still selling and servicing the Sachs Dolmar~ Dolmar ~ Makita lines of chain saws....
Scott
Man that's a lot of good info! The 540 is what got me hooked If I am correct it's very similar to the 115... I think my 540 needs a coil :-(The SD 114 used a 2 piece transistor ignition, that has been NLA for ages here in the US. But You can snip the wires from the trigger under the flywheel or remove the trigger and replace the coil with a 1 piece coil from the 116si,120si,PS6000,PS6800 series saws. The flywheel had the same timing so no change required there. That saw is circa 1979-1980 due to the offset chain brake lever design. And it is wearing the European spec Muffler that had a awesome note. The issue that series had was the Tilly HK series carbs that were problematic due to the plastic module body that held the metering valve and circuits. There was a walbro replacement that worked much better. That age SD 114 is the saw that got us hooked on SD back in 79' and here we are years later still selling and servicing the Sachs Dolmar~ Dolmar ~ Makita lines of chain saws....
Scott
I saw this on eBay this morning, I was curious if it was yours
Well put Scott
The serial number for this saw is 114/052 125
the chainbrake cover was missing when I got this saw i replaced it with a cover from a 117 I do think this saw is a later 114 all the part numbers are preceded by Dolmar west Germany rather than the older styling of part number and made in west Germany
Have you ever seen a bing carb on these saws
There a hell of a big size in the flesh to a 8 ...if you want one ..I have a good used 9 pin you could play with.That is just The ticket great find they could be handy for milling as well
That sounds just right simonThere a hell of a big size in the flesh to a 8 ...if you want one ..I have a good used 9 pin you could play with.
I will send it down to youThat sounds just right simon
I got a vertical shaft 14hp petrol engine ready to go on sawmill and I was thinking about a 9 pin sprocket in .325 , matched to a 42" bar
