Black Dog Chainsaw
Mak-Crazy
- 6:42 PM
- Jan 8, 2016
- Indianola, IA
Funny you should mention the closed vs open. A little birdy flew me a package from out east with a NOS closed port 115/520 cylinder. Not sure what model it originally came on but I have been looking for a closed port top end in the last 20-30x 111/115/520/540 saws that have passed through the shop or looked at during picking. I'm pretty pumped and am thinking about a little port work after running one stock. Since I have 5-6 of these I'll be able to see how closed vs open cylinder performs stock. That may determine whether I do any port work on it. I just have to find all the best of the best parts to put one together...Hummmm tricky one as personal taste is involved as to what you find ok....response is what you would expect from open.. V.. closed trans port 50cc class saws. There the older 2 port closed sort in the 115..52cc (110 closed port as well ) and therefor you dont get the same "Style" delivery as a Quad port with small uppers like a 346xp Ne or a 5105 dolmar...The 111..52cc (109..43cc) has a fraction less snap being old sort open port. Having said that Tor.....the 115 and the 110 have much in common with the 242 and the 254 in there power and performance ...In the cut they pull hard under load around the 9000,10000 rpm (standard saw) with the 115 running 3/8 as standard and the 110 on .325 with a 8 pin rim. The 110 is on a 8 because the clutch drum is of the bigger sprocket drive size and 7 pin "normally' isn't a option. The 110 has high chain speed due to this for softwood de limbing , making it useful for this task. Some of this is fact and some is my opinion of corse but "ALL" are far from "Slugs" ..imo....you just need to try some for your self Tor and make out how they feel to you
had I known this cylinder was going to show up I would have spent more time looking through Steve and Scotts NOS supply of parts for this series...
PS: thanks Steve and/or Scott!!!!
[emoji7][emoji7][emoji7][emoji7][emoji7][emoji7]
