super3
- 3:54 AM
- Dec 31, 2015
- Indiana
Mike yours looks a model 308. Single stage cylinder.
Diverter rod and throttle cable mount in a different spot than mine but they operate the same way.
Like you said,
Lever forward engine goes wot and splits w/o holding the lever, goes full stroke, returns automatically and drops to an idle.
My 348 has a 2 stage cylinder, 2 diverter valves and a shift valve controlling the flow between the 2 cylinders.
You may have known all this already.
The part I was referring to in the last pic is the auto stroke block. Along with the auto stroke rod it will shift the lever back into the engaged position at the end of the return stroke without ever touching the lever.
Like you said,
