Tecomec pistons (PORTING HELP)
10:34 AM
I grabbed a few of the 44mm 026 slugs on a DOD deal.
I'll do a comparison vs. OEM vs. Meteor when I get them.
That MS360 piston above looks to have wider skirts. The meteor 036 slug and the meteor 046 slugs both have wider than OEM skirts.
10:34 AM
While some pistons may be a bit heavier or lighter, I have found the biggest difference in weight is often in the piston pin. The AM pins are often not tapered like OEM. I use OEM pins whenever possible, but you must check size to ensure they are the same ... not always unfortunately!
XP_Slinger
They’re Just Saws
10:34 AM
Central NY
Dang arm twisters lol
@RIDE-RED 350r is good at that;). Nothing wrong with having a builder sitting for a while, just lets you plan it all out. I STILL have to build my 281 but that 254 jumped ahead in the line because it needed less money to get it going.
Mkinslow
9:34 AM
Tennessee
No nothing wrong with it at all. I just get ready to hear it run and then it’s hard for me to slow down and chill out on them
Keith Gandy
Maxima K2 40:1 87 Pump Gas
9:34 AM
Provencal, Louisiana
I was thinkin the skirt looked a good bit wider also
Mkinslow
9:34 AM
Tennessee
Compare all of the dimensions between the Tecomec and OEM. Overall height, pin to crown heights, skirt width, etc.
I can put up the dimensions on the new one but I don’t have an oem to compare it too. But maybe someone has one we can check it against
Stihlbro
10:34 AM
Virginia
I also mocked up this jonsered 630 piston. Windowed, single ring and 48 mm. It was a shorter skirt. Piston pin to crown was exact, the good side is it would be more intake duration with just a piston swap. It was like 6 degrees more. Again it was several months ago. If you would like to mock this piston up, let me know.
Joey
Mkinslow
9:34 AM
Tennessee
Joey
Ok thanks. I’m still learning about duration and such in saws. But that’s why I’m here. TO LEARN and help were I can
RIDE-RED 350r
10:34 AM
Blossvale NY
Joey
My eyebrow raised when you said the J-Red piston had a shorter skirt! Sounds like that piston could play a significant part in building a strong 48mm 365! I would assume the J-Red piston is lighter too, which could also play well. How nice is instant +6 deg intake with zero grinding
