Magic_Man
Oh Yea !
- 8:29 AM
- Dec 4, 2015
- SE Ohio
AgreedWhat I'm getting at is even on a stock vehicle it's best to set at full advance and then check the timing at idle. You'll find a lot of mechanical advances that are stuck or improperly functioning. If you would set the distributor where it idles best and leave it you may have too much timing to start due to a stuck advance. Or the springs could be weak or broke and the late timing will cause excessive exhaust temps which will crack exhaust manifolds and intakes near the egr port. Or the advance could have too much range and have too much timing at full advance and you'll detonate or burn pistons.
Also, it's good to look at the timing through a sweep of RPM, at idle a loose distributor gear or timing chain will usually not show up. If either are worn the timing can be erratic at certain rpms and steady at others.
