Gearshifter
- 2:16 AM
- Dec 20, 2022
- New Zealand
Hi guys this is my first post here . I've tried searching for my answer but havnt had any luck
I've got a stihl 462 top end and possibly a crankshaft that needs replaced . I got the saw dirt cheap as the piston went and demod the saw ..
What I'm wanting to know is can you put a 460 top end etc on a 462 ? What parts are interchangeable? If not are there any aftermarket parts available for these saws as I only do firewood for myself and family
Thanks in advance
Update : have pulled apart the saw. I'm no expert but everything looks good apart from piston and crankcase
Update 2 : ordered another flywheel crankcase , piston , gaskets , bearings and seals . I've put the halfs together but there's a gap between the flange
Update 3 :
Saws back up and running ! Had a 25 inch bar on it cutting bluegum . Thought the 25 was abit too much and sorta struggled ... so put a 20 on and it didn't back down .
I hear people say they can run 32s on these , is that with soft wood ?
Thanks everybody that helped me get the saw running
Thanks in advance
Update 3 :
