maulhead
- 12:20 AM
- Dec 30, 2015
Poly flywheel Stihl 066 up for sale. It has the white oval plug by the oil cap, I think that means it's a short case saw. I'm not 100% well versed on 066's thou, so do some reading in the 066/660 threads.
Starts runs, idles, oils, brake works. Few things I will point out about it, 2 of the 3 cylinder cover screw holes will need some attention. Front one on the flywheel side seems to have something broken off in it, the hole on the clutch side is stripped. The bar studs are two different lengths. There's a chipped section on the tank/handle.
Not sure where to price it at. A running 066 out to be worth $525 I think.
