- 7:58 PM
- Dec 28, 2015
- Central Ohio
I have a few 044s that need a new home
I have a MOFO 026, a MOFO 360, a MMWS 261, MMWS 362, 10 mm 044, MS 440 (both with timing advance and base gasket delete), and a CFB Hybrid, and non of them are going anywhere!
Yes, Dr Al does a great job on both 026/260 + 036/360, but the 460 he built for me really screams!
Don't over look a good running MS 440, you may be surprised how well some of them run. My fastest 70 cc is a 10 mm 044, but my MS 440 will keep up with a lot of 10 mm 044s.
Put an angle fin top end on it,pm me i may have one you will be impressed.I have a MS440 with
Meteor cylinder and piston, it runs good but I need to cut some wood to make sure everything works okay.
There work saws not race saws.once you run a woods ported saw you will never want to run a stock saw againGood to know. Not looking for a racer,just a good saw.
Put a 10 mm crank in it and slant fin topend on bothI have one but it’s going on this build. With a 12mm crank and oem piston.
Dont think so unless you got a real old giordini maybe why.whats seial number of case i can tellDo any straight fin non decomp 044s have a 10mm crank?
Agreed or 10 mm ported 12 mm made 044 046 is deff best of both worlds12mm bottom 10mm top ported best of both worlds
Why would you want a 10mm crank in it?Put a 10 mm crank in it and slant fin topend on both
If he allready has a 440 with aftermarket top end why build another,id build 044 10mm with that topend.then make 440 he has with meteor piston and top end a hybrid.then hed have best of both worlds. My mailbox is still empty lol fyi.no sodium elements have came yet bro.Why would you want a 10mm crank in it?
Ok I got what your saying now. I've been working over everyday. Not getting home till 6 pm so I haven't been able to make it by the post officeIf he allready has a 440 with aftermarket top end why build another,id build 044 10mm with that topend.then make 440 he has with meteor piston and top end a hybrid.then hed have best of both worlds. My mailbox is still empty lol fyi.no sodium elements have came yet bro.
Its cool,make that ot when you can with them little ones and holidays comingOk I got what your saying now. I've been working over everyday. Not getting home till 6 pm so I haven't been able to make it by the post office
Agreed Mike, my best runners were 440 bottoms with 10mm tops..12mm bottom 10mm top ported best of both worlds
