Poleman
- 2:00 AM
- Jan 18, 2016
- Rapid City,S.D.
Need some ideas guys. I'm working on an older 036 that is in great shape and hasn't been abused. I scoped the cylinder and it's perfectly clean on bother sides. 160lb Complete @4k feet.
ISSUE: Saw starts and runs fine...the problem is wot.....tach set to 12,8 which it goes to then about 2 seconds in it jumps to 15,5+, kinda like a 4bbr opens up.
I've replaced crank seats and saw hole 8lb pressure and vacation. Replaced the intake boot, impulse line, carb kit and fuel line.
I've tried a different carb and coil and it still does the same thing.
Fuel system checks out as it should. Carb seems good. About the only thing I haven't done is pull the cylinder.
Any ideas I haven't tryed.......yet??????
