Huskyslinger
- 3:11 AM
- Apr 13, 2020
- Wa State
https://m.quoka.de/handwerk-hausbau...25a267426247/solo-690-680-670-motorsaege.html
Brand New oem p/c for a decent Price.
55 or 56mm, there are 2 types of cylinders.
that's awesome but will they ship to USA? Need to translate it though
Keep in mind that the 55mm and 56mm top ends are not directly compatible with the 680 chassis. Those are for the 690 (55mm) and 603 (56mm), which use a different
crankshaft with a longer stroke.
The 670 and 680 use the same crank, and the 690/603 use a different crank.
That jug may be salvageable. For a piston, I would take a look at the big bore 372 piston. They seem to have about the same crown height as the 680
piston and also use a 12mm wrist pin. An 064 piston is another option.
I would clean up that jug real good, smoothing out those grooves and finishing everything down with 400 + 600 grit sandpaper and cutting oil or
Liquid Wrench. I think you can make a runner out of that.
