jakethesnake
I Am The Snake
- 1:39 PM
- Feb 5, 2016
- Here & Now
Luck, luck.
Not sure anything gets along with diesel. Do they make a rubber gasket for that?Ugh, get it back together and the damn top cover gasket is seeping fuel. I figured I would have to do this job about 5 times to get it right. I coated the gasket with Permatex High Tack as I've been doing to paper gaskets for decades. Does this stuff not get along with diesel?
Every gasket I've seen is paper, wonder if anybody makes a cork gasket for it?
In the tractor of our production
Permatex got back to me, they confirmed that High Tack will work for this application. I did file down a rough spot on the cover before I reassembled it, will recheck with a straight edge. What sort of torque should I use on the two 1/4" bolts that hold the cover on? MF has no service info on the pump whatsoever.
