LAWN BOY
Pothole
- 3:22 AM
- Feb 27, 2024
- Merrill, WI
What do you use for a cleaner in your ultrasonic cleaner?View attachment 406189
Installing a hot/cold station and electric pressure washer with a 100’ retractable hose. It’s not a gas, but super convenient!
View attachment 406190View attachment 406191
Ultrasonic cleaner ftw!
View attachment 406192View attachment 406193
I thought they would be a shìtshow of epic proportion but other than a couple oil leaks I've seen no issues with them. Time will tell but there's several 2.7's in trucks over 100k that are in for services with no real complaints.
Only ultrasonic cleaner I have I use for my brass for reloading. I use some stuff that RCBS sells for that purposeWhat do you use for a cleaner in your ultrasonic cleaner?
@redline4 you use an ultrasonic cleaner as well, right? What do you use as the cleaner?
They sound weird. They are ridiculously complicated. They kinda suck to work on. But, a few high mileage oil leaks at the PCV oil separator and some evap purge pumps early on that was a part issue is all the problems they have rolled in with.What do you think of those 2.7 In the 1500 Ed?
Or should I just go sit in the corner now...
So really, they are one of the better engines out there right now for the General..
You should move on up here and work on them with me.
I just use dawn dish soap! I tried a few thing, but it works good and cheap to keep clean waterWhat do you use for a cleaner in your ultrasonic cleaner?
Thank you! I'll have to give that a try. I was thinking about trying simple green ment for aluminum.I just use dawn dish soap! I tried a few thing, but it works good and cheap to keep clean water
Only ultrasonic cleaner I have I use for my brass for reloading. I use some stuff that RCBS sells for that purpose.
Naw, you move down here and get mediocre on everything with me.
I'm not sure the world could handle the ordinary stuff we would accomplish.
I do get to split the crankcase on a Northstar today. It's been quite some time since I've had one apart...
Not following…it might not be a bad idea to say a prayer before cutting them, haha.Prayer tree?
Awesome engine, nasty to work on. A buddy and I changed head gaskets in his. It took 3 full weekends. A dealer offered us a great deal to repair 2 more. We turned them down.I'm not sure the world could handle the ordinary stuff we would accomplish.
