tree monkey
- 11:29 PM
- Dec 14, 2015
- wi
I got this over 20 years ago for tuning my 440 engine,
Any theory why the second set of magnets are reversed S to N?my findings were interesting. the timing seems to jump around at idle, I took an average of 18 deg and 50 deg above 5000 rpm. this seem way to much to me.
I advanced the timing with the key by 7 deg using a deg wheel, and redid the timing light test. idle 32 deg, over 5000 rpm 64 deg. well ok. so the ign sparks twice per revolution. so stock timing is 9 and 25. my advanced key is 16 and 32.
The other set of magnets still seems to affect rpm even when running a regular carbaccording to the tech ay stihl 1 set is for spark, the other is for the carb, said it does not spark twice per revolution. after 2 days of testing I found that not to be true on the 261
Well let us know if you find such a thing. What's the highest you've seen one get up to?I meant to say I need a timing light that goes over 15k
Can u get a 261 coil work in a 661?yes it does. I can't prove what I think is happening without a tack that goes over 15,000 rpm, but I believe that the coil on a 661 starts to retard the timing at around 13,200, and a 261 at around 14,000.
I didnt try a 261 coil.@Redfin, I think tried. I don't think it worked
