One case tool to rule them all!
Jimmy in NC
6:47 PM
North Carolina
flywheel ... m8x1.0 and m10x1.0 both RH
the pitches for clutch side that I used are m10x1.0, m10x1.5 m12x1.0 m12x1.25 m14x1.0 m14x1.25 .... all in the kit... all LH thread
m8x1.0 and m10x1.0 both right hand
m10x1.0 and m10x1.5 both left hand
m12x1.0 and m12x 1.25 both left hand
m14x1.0 and m14x1.25 both left hand
Sent from my SM-G955U using Tapatalk
Frank bierce
3:47 PM
Now I need to put something in the top to keep the top layer of tools in place, if the box gets tipped over. Trying to figure out what I will use for that...
angelo c
Coal Member
6:47 PM
Another piece of the same styrofoam shaped and cutout (mirror image of tools) to fit top...(glued to lid)
hoskvarna
5:47 PM
Iowa
Or a piece of foam from a couch cushion trimmed down
Sent from Hoskvarna Hills
Glock37
6:47 PM
Monroeville Pa
I was installing new crank in a 880 flywheel side went in great got gasket ready to install crank in pto side i was drawing it in and it stopped the crank is bigger than the inner id of the install sleeve so i had to use a spacer to allow the crank to pull thru inner bearing race
I found out bigger saws like the 084,088,880, 3120 have this big shoulder on crank
I called matt hes working on getting sleeve made to use on the bigger cranks
Matt is very good to work with to help us saw nuts
PogoInTheWoods
6:47 PM
Ohio
He wanted us to delete some posts in this thread, but that's pretty silly considering that all he needs to do is reply.
Hmmmm. So he's boycotting the site (and maybe even HLS) over not receiving some sort of preferential treatment.
Where have I seen that before? LOL
Jon1212
Birch! Please.....
4:47 PM
Utah, unfortunately.....
Actually it goes back to "As Is", and the interpretation of the definition, with caveats.
I'm sure a search of the forum will be enlightening.
