- 10:46 AM
- Jan 8, 2016
- Farmington, CT
the link i posted is justgreatbearings on ebay... theyve done well by me so far and usually have 6202 nachis for a great price
Sucks $25 to ship to Canada,,,,http://m.ebay.com/itm/10-6203-2NSE9-C3-NACHI-Motor-Quality-bearing-6203-2NSE-6203-2RS-EMQ-bearings-/142007609678?hash=item211050294e:g:GuIAAOSwcdBWR3RP&_trkparms=pageci%3A8dc161ea-fc21-11e6-8bf0-74dbd180f6fa%7Cparentrq%3A7a74ff7915a0a60cb72932eaffeb4aef%7Ciid%3A1
6203s.....10.....cheap just pop out the seals!
+1 that's how you do it. Easy!pretty sure its in my vids somewhere lol... but ... its really simple with a small flathead screwdriver. the seals are not hard to get out at all
Those Nachi bearings seem to be very good. Have used in several saws with no problems, yet.Using the term "OEM" vs. "Aftermarket" in the saw world for bearings is kind of moot, since all OPE manufacturers source bearings from many companies. I have seen Stihl use: NTN, Fafnir, slacker, Nachi, SKF, and SNR in chainsaws, brush cutters/weed eaters, backpack blowers, and other equipment. I've seen Husqvarna use slacker, SKF, Fafnir, and NTN. they've even used different brands of bearings in the same model of saw, depending on where it was manufactured.
Matt pretty much has a video for everything.lol he has helped me more times then he will ever know. Thanks Matt.
What do you guys use and why? I put cross bearings from hl supply on my 670 champ they seemed good. Gonna do a complete rebuild on another saw just contemplating the bearing situation.
No I Have another 670. I'm glad you are happy, my older saws all start better than the newer onesIs that the saw In got from ya? In any case just wanted to tell ya One pull start on that 670 I got from ya man it runs good.
I was having same problem with jackshaft bearings on my mower. I didn't trust that the seal would stay in place after popping it out to grease them. I drilled a small .055" hole through the seal and greased them with a needle tip grease grease gun. So far no problems.I try and look at bearing replacement this way, on the older "firewood" type of saw that is not going to be spinning a very high RPM I'll go with the Cross or FarmerTec bearings. Newer "Pro" builds get SKF and the others previously mentioned. Where the dividing line is may be a bit fuzzy at times as well. I've also been putting Chinese bearings in my own saws just to see what they'll take, so far so good. The biggest beef I have with the cheap bearings is on sealed units(for other applications) a total lack of lubrication, I've been putting guide bearings on the sawmill four at a time. I finally popped the seal off of a new one and made that discovery, so there I am packing grease into a brand new sealed bearing like an idiot...
Whatever became of dieselfitter? I thought of him with the recent thread on the stroker crank...he did that on one of the Poulan CV models years ago.
Mark
A big OEM vendor such as Husqvarna and Stihl buy direct from the manufacturer and yes, that does alleviate that issue quite nicely.Stumpshot.... We are assuming the saw manufacturers aren't getting fake ones.... though your point is taken.
Even fake rolexes are getting better and better these days... the top guys having a harder and harder time telling them apart. Crazy world
