Scott chandler
- 5:06 PM
- Jan 1, 2018
- North Carolina Advance
i have a 394 with conversion to 395 and everything has gone great up until i try to start for first time. No fire at plug. It has a new Oem coil new Oem plug wire new spark plug and tried two different new plugs New switch new kill wire . Even pulled kill wire from coil. Key is in crank and flywheel in right place. Flywheel magnet is strong. Coil spaced with business card and i don't know what else to check. Old coil is probably ok now that it still doesn't have fire !! Thought that was problem. I don't know what else to check and appreciate any suggestions. This saw was running until somebody straight gassed it. Saw even looks new all over but sat for years under bench. Can flywheel go bad over time ? It's strong enough to pull coil tight when adjusting gap so any suggestions Thanks
