Need some help on a 394
redlinefever
3:26 AM
Iowa
Was going to start a build thread on a Husky 394 but got bearing in and installed only to find bearing on pto side loose on the crank . so I'm asking a few questions one what's everyone's views on a non oem crank ? I'm leery on non oem . If there is issues does anyone have a oem crank in good shape they would sell?
mdavlee
Hillbilly grinder
4:26 AM
TN
I have 3 busted cases with cranks. Let me look after lunch and see if I have a 394 crank.
redlinefever
3:26 AM
Iowa
First I would have to rule out letting a machinist knurl the crank you have and put some loctite on when installing the new bearing, before buying another.
Thought of that but didn't want to chance the integrity of the saw I don't want to worry about anything on a ported saw!!
mdavlee
Hillbilly grinder
4:26 AM
TN
Got a 395 crank in a set of cases. I do have the ywheel. The key was sheared in it when I got it. Crank looks almost new.
redlinefever
3:26 AM
Iowa
Do I need the flywheel or will the 394 flywheel work?
jacob j.
Lord of Cargo Pants
1:26 AM
Coastal Oregon
You guys should have seen what I gave to the scrap metal guy last year- I had 70 pounds just in blown cranks and over 50 pounds in broken case halves that he hauled away.
peter92
6:26 PM
maryborough qld aust
where the hell you getting that much from haha
redlinefever
3:26 AM
Iowa
Well thanks guys got a crank coming mdavlee hooked me up with a crankshaft should have a build thread coming soon once I can get the lower end put together and get some numbers of it before and after
