think I am on my 13th 661. Ran em stock, modded, and fully ported. At the time the 661 came out I had 5 660s and an 066. After running them side by side for a bit I started selling off my 660s and replacing with 661s.
- vibes are way way less on the 661.
- economy is way better on 661
- 661 is always on tune.
- stock 661 torque is without question much much stronger than a stock 660 or muff modded 660.
I run good bar oil, good gas and 2T oil at 32-40:1, clean my air filter, and the saw has treated me well. No issues on any of the 13.
These days 99% of the time my ported 661 wears a 36" or 41" bar running full comp .404 RS. No issues. The other ported 661 wears a 28" lite running 9pin full comp 3/8ths RS and it HAULS! Again no issues.
Possible issues -
1. the 661 likes to warm up a little before you cut.
2. shutting the saw off immediately after a good long cut and then trying to restart it.
3. running the old 4700 coils. They allow the saw to go too lean.
4. running the old intake boot.
5. opening up the muffler too much on a stock saw.
6. running a 7pin sprocket on anything under 32" bar. Stock 661 has the torque to pull 8pin right out of the box. A 7pin 661 = slow. None of my stock or muff modded 660s could ever pull an 8pin faster then 7pin even on a short 20" bar.
7. always "resetting" the saw. Saw learns/tunes pretty fast. A "reset" should be tried when it's really not working right.
New model of anything comes out...usually has a few bugs. 4700 coil and old intake boot were the bugs. Stihl fixed and warrantied them both.
muffler mod 661 - 41" bar.
muffler mod 661 - 36" try doing this with a muff mod 660.
stock 661 vs 3x port muff mod 660
ported 661
