MG porting
- 12:52 PM
- Jun 28, 2018
- Wa
What's it sitting at now or do you still have it?Mine was .018 in stock form
It's right at .016 darn thing runs pretty darn good I'll most likely leave the transfers where there at but was going to raise the intake to see how it will do.Sand a bit from band, or run .016 if it’s on the money.
I’ve heard from reliable sources that some old 066 left the factory at .017.
Epoxy the intake and start with classic numbers, 100/120/80. See what you think.
Still have it. It’s my 066 work saw jug. I had it on the race saw while my other jug was getting re-done. It’s been machined at least 3 times now, somewhere between .070 and .080 off the base. Squish remains at .018What's it sitting at now or do you still have it?
I’ve never had any problems with oem decomp valves. In fact, I prefer them.
The small air leak people talk about them having is incomprehensible to me in so far as how it would cause engine harm. It’s above the crankcase.
Once the saws get to around 75cc, I prefer the “smart” button. My need to show off my strength faded 20 years ago for me. In fact, if anyone wants to start a big saw for me I’m more than happy to let them, thank you very much.
It’s generally not the compression or cc that bites ya, it’s the saw firing before TDC. The decomp allows you to get more speed with your pull and not get bitten as often or quickly.
Even on 60cc saws, a decomp that’s there is nice for initial startup after a build with an oiled cylinder. It makes the starter mechanism happier for sure. After that, I never touch it. The saws start better without it being depressed.
I get what you're saying. But the saw wouldn't have been four stroking then either. So it wouldn't have been really any different than a cracked impulse line or fuel line. Or slight air leak from somewhere elseI bought a scored 394. Decomp killed it. Only place it leaked. They ran it long enough that the decomp sucked enough extra air in that it scored but didn’t lock up
Maybe when I get old I might get smart enough to put a decomp on my Saw's.lolI’ve never had any problems with oem decomp valves. In fact, I prefer them.
I might take a little off the squish band while I got the jug off to build up the intake but it's happy where everything is at now but never know it might gain a little more poop.lolStill have it. It’s my 066 work saw jug. I had it on the race saw while my other jug was getting re-done. It’s been machined at least 3 times now, somewhere between .070 and .080 off the base. Squish remains at .018
Just ATDC?A leaking decomp will never suck in air it's impossible isin't it?.
When is there a strong vacuum above the pistion that it pulls air in through the decomp? I don't get it.
If piston rings are above exhaust port moving up or down (compression going up and expanding combustion going down) it's always positive pressures with engine running.Just ATDC?
