- 4:28 AM
- May 11, 2022
- Virginia
Got two barn find saws some months back. A Ms460 and Ms440. Ordered a basic set of parts and tools for testing and finally got into them today. This thread is just for the Ms460, I will make another thread once I get a little bit deeper into the 440. The home owner said her uncle went through them and said the engines were trash and have been sitting for some years. The saws had the brutal lives of being a rental. So far here are my findings:
1. Lots of missing parts of course. Pulled the exhaust cover and the piston looked surprisingly clean with no transfer.
2. Fitted a recoil on it and pulled it over, no spark.
3. Compression test with innova tester showed 90psi wet. Didn’t want to run a dry test at first since it’s been sitting for so long. Felt really hard to pull over for just that much pressure.
4. Carburetor was full of old gas but surprisingly there was still fuel pressure at the carb as I was pulling the carb off the lines.
5. Performed vac/press test (my first one ever) impulse line was rock hard and leaking, I flipped my stihl adapter over and plugged the line manualy. Put Rubber stihl gasket on the exhaust and found the crank seal on the clutch side was leaking when I sprayed oil on it. I see a bearing not a seal on this side but there’s a snap ring that looked to be in the right place but the bearing looked to be pressed out. Didn’t hold pressure or vacuum well, leaked down slow and steady.
6. The clutch was shot but I didn’t see any other remnants of parts in there. That side of the saw was filled with oil like the leak was there for awhile. Checking for play in the crankshaft it felt pretty tight. Had almost no up/down wiggle and none side to side.
Never took one of these a part to this extent. I have an automotive background so I’m very good mechanically.
Current shopping list is:
1. New carb (any suggestions?)
2. New coil (any suggestions?)
3. Impulse and fuel lines (already have)
4. Clutch and oil pump
Not sure what the best plan of attack is on this leaking seal/crank area so I’m looking for suggestions/advice. Do I have to split the case and do the bearings or should I since I’m this far into it? What is missing/out of place on that clutch crank seal area? I have to get a long t27 bit tomorrow since the stihl chainsaw wrench doesn’t fit in the narrow holes of the cylinder aswell as some parts cleaner. I have a Walbro carb rebuild kit aswell as an aftermarket carb just for testing purposes. Thank you all for your help!
