- 8:28 AM
- Dec 31, 2015
- East Jordan, MI
Note to self...look for RI speed maple for test wood
Is marble hard?Wood was like marble Kevin. Would you like me to find another test piece of something different to retest?
There is a set of spikes availible, because older ones and newer ones are different. That set can be used with the newer slim chain sprocket cover, not with the old cover. The set would be 0000 660 0800, including inner spike 1142 664 0500, outer spike 1141 664 0501, 2 screws 9008 345 0960 and 2 lock nuts 9214 320 0700.
No sir. Didn’t have time to laugh. Too busy trying to find a bigger trailer to drag to Rhode IslandYou guys probably all laughed behind my back when I made pine cookies didn’t cha?
How did you know my knick name is old balls?
Unless they've removed it on a new version of the muffler, there is a shelf that separates the intake side of the muffler from the exit, forcing the exhaust to bounce off the front of the muffler and then back into the exit hole. In other words, a baffle.
Removing this baffle hugely increases the power as well as the noise. And I mean it really increases the dB's. On the ones I do here, you will see at least a 25% improvement in cut times. I have a video showing one that improved cut times by about a 1/3. A good way to tell if your muffler has a baffle is to listen to it. If it isn't loud, it has a baffle. Another way is to remove the muffler and look into it . If you can not see all the way through it, it has a baffle. Here is one with the baffle removed and the exit widened with sunlight shining through.
View attachment 223530 Just picked up from dealer. The outer spike you are showing! Is this the match for the stock inside? And do they make a larger set?
