- 5:06 AM
- Jan 24, 2017
- Berkshire County, Massachusetts
Excellent...
Do they make a $100 tool for this?it's not easy to get the cylinder on the piston
I bought the 11mm circlip tool. I’m an idiot. One saw, MS361, needs it.Its probably 2 hundo being new and all.
Rent that sucker out to 361 fanatics on here or AS.I bought the 11mm circlip tool. I’m an idiot. One saw, MS361, needs it.
Impulse buy after bleeding thumb.
building up a new cant to test on
also going to need a roll of chain Stihl 33RS should get around 17 or 18 tests with the roll. Testing with 28" tsumura bar. .050 3/8 91dl. 7pin sprocket.
yep need to buy another cheep setModify a ring compressor.
Did you measure the width of the band?
Thanks Man. Can you tell me how space is under that transfer divider while your at it? Kthanxbye.I will the next time I have it apart, anything for you sweetie
So they make two versions of this thing? One m-tronic and one with a regular carb?
