Modifying Max-Flo Filters
RI Chevy
11:50 PM
earth
I have been studying these Max-Flo Filters and am curious if anyone modified or does anything to the plastics that come with the filter setup?
Seeing that the covers are pretty cheap, I was thinking about drilling some holes in the sides of the rear cover to help get more air quicker.
I was also thinking about drilling some holes in the flat plastic plates so you could gain a bit more air flo from the top of the filter, seeing that it appears to be un-utilized.
Any thoughts? Anyone already do anything to their covers?
ARPILOT
10:50 PM
Midwest
might check out FrogSkinz, some guys here were using them..... I think this fits with what you're trying to do if I understand you correctly.
RI Chevy
11:50 PM
earth
I have checked the frog skinz out. Not sure if I would need them with the foam filter.
I do like to run the saw without the cover and just the flat top cap, but was just looking for something different. I like the added protection of the cover. Just looks like the cover makes the filter lose a bit of air flo.
11:50 PM
I’d make the holes on the sides, fastest path to filter.
RI Chevy
11:50 PM
earth
That is what I was thinking.
mdavlee
Hillbilly grinder
11:50 PM
TN
I added some holes on the 046 kit I had. I sent it to Dan up there to try and run on the dyno. You do still need the foam to stay dry if it's rainy out. It won't absorb much water but it could after a while in it.
RI Chevy
11:50 PM
earth
Cool. Thanks Mike.
Did you drill holes in the sides of the cover?
RI Chevy
11:50 PM
earth
So many guys on here cut with open foam filters. I figured using a modified air filter cover would be just a bit better than using it covered???
Redbull661
661 hoarder (BlueBallz)
10:50 PM
wisconsin
Me thinks it would be easy to do a simple test.
- 2-3 cuts with filter cover ON
- 2-3 cuts with filter cover OFF
How much faster is it might determine if holes are needed. Or maybe it's the same speed. IIRC Joe said the max flow filters let a lot more air in then a typical hd hd2 filter.
I just did holes on the bottom of mine. Let's more air in, lets chips fall out easier, doesn't let water in.
mdavlee
Hillbilly grinder
11:50 PM
TN
I thi k it was one on each side and one on top. I had pictures somewhere but not sure where now
RI Chevy
11:50 PM
earth
When I get a chance, I will do this test for the good of the order and report back. I like the holes on the underside! [emoji106]
