Cerberus
Cerberus the aardvark, not the hell-hound!!
- 2:22 AM
- Jan 20, 2020
- Florida (tampa area)
You and @huskyboy are saying my mods here (OP) fail becauseTHIS!!!
What, specifically, are you guys talking about? You realize my post shows standard-type airboxes(my scheppach & my echo 355t, although every saw I own has the same airbox restraints and the same mods to overcome them)How much faster will the saw be when you defeat the air injection and the filter clogs faster ? Imo modifying the air box should only apply to old style filter setups with no air injection. Then it makes sense.
Would like to hear what on earth you mean, are you confusing the Husqvarna air-injection system somehow? Plz do explain as I can hardly figure out what's meant by their "air injection"....
Echo (and the saws I'm familiar with) have negative pressure at the airbox courtesy of that lil rubber hose/porting to the flywheel-face of the saw, see the Echo video in my OP post#1 for "proof".......My 355t, for instance, already has openings on the back of the case's airbox They simply put several ~4mm wide bars/rectangles along the bottom of the airbox.....I filtered those and added an additional inlet up higher on the same face of the airbox, and I rubber-plugged the H&L port.....For my 355t, and all the saws I own actually, this:
- allows more air-intake at the airbox,
- lets less debris in despite more air-intake (wayyyyy less debris, although that should be expected when you eliminate the wide-open pathways on many saws' airboxes, tsk-tsk to the manufacturers there!)
Coupled w/ muff-mod & retune (and run on canned gas, though next week will be in LA doing storm-damage & setup doesn't allow it so will be 1st time relying on mixed pump fuel ), all of my saws have run great I never need to tinker w/ them anymore just cleanings and I never want for power as I don't over-size the bars I use (and all of my saws would happily take 2-->4" longer bars but I've got them all paired 'appropriately')
Plz be clear in describing whatever Husqvarna(or other/any) 'air injection' would have been defeated by my mods, you make it seem like "old style" is anything w/o this "air injection" but google was not heavy w/ any explanations on the husqvarna air-inject (and if you're talking about another type, please be specific....but if you're just guessing that what I've done hurts an echo 355t, or most types of climbsaw, I can assure you it does not I've been running saws hard this way and they just get stronger as they're aging )
