Adirondackstihl
- 6:31 PM
- Dec 4, 2015
- Upstate NY
Sure did!Cuts quite nice!!
Was fun to noodle with!
DE80 - Q port and pop up compression release
To be continued...
Mark
These saws were so far advanced for the time period very few actually know much about them .The only big deal is because of how they were made there really isn't much you can do with them to enhance them .This one ,the 82 cc Macs have as big of a cult following as 2100 Husqvarna ,I have both so I guess I'm in two cults .Went from a build thread to a deep discussion. lol
Yup! Did the grease, my they kept flying out of my fingers. hahaRegarding bad chrome I think McCulloch had some quality problems during that time period .It may have been a problem due to not being able to get that hard Rhodesion chrome or their process .However it was about the time you didn't see as much chrome on automobiles as there once was .----put some grease on those needles.makes it a whole lot easier .
TJ . does your oil pump have 1 screw holding it in and did you use the spring plate at the back of the pump , im up to that part now but cant bend the plate, i cant see what holds the plate when its bent as theres nothing for the top of the plate to clip in toSo I think I narrowed my air leak problems down to the auto oiler not sealing against the crank case. Have a new gasket on order for that as well as a new piston assy, manual pump gasket, and tank cover gasket. Hoping those will solve my problem. Really wanting to get this thing in some wood.
Yes havent used sealant on the gasketThe plate is simply wedged into place. And sealant should not be required with the pump gasket.
ok thanks so it doesnt have to be pushed right back , ill try it tooro and see how i goYou just need to get the plate wedged into place to the extent that it has a bit of an arc to it. Going too far can actually bend it which requires straightening and flipping it around and going from the opposite direction, but whatever temper it had has been compromised and it may bend again in the opposite direction. Two screwdrivers (one on each side of the pump) is the best method to push the top of the plate into position. The above stated, I'll qualify it by admitting that my experience was with a copy of an OEM plate that could have been less rigid than an original.
