- 2:44 PM
- Dec 29, 2015
- Strong Island NY
Unforeseen issue. I’ve never put a 44.7 on an 024 chassis, 44mm certainly fit and have ample side clearance (as do 44.7 on 44mm cases-gotta wonder if that’s why they didn’t go to 45mm).Thinking a bit more on how to attack the crankcase with a die grinder/burr and not mess it up.
Planning to remove the fuel tank and brake bail arm to enable better access.
I can make up a steel plate with 3 holes:
- Two small ones to bolt it to the crankcase flange
- One large 1 .875" diameter (47.62 mm) as a guide for the burr. This would give ~ 1.5 mm/side clearance between the bottom of the piston OD and the case ID
I can mount the plate and put a depth stop on the mill to prevent going below the desired depth. The plate will prevent the burr moving beyond the desired circumference.
Would 1.5 mm/side clearance be enough to prevent piston contact at high revs? Or should I go more? A 2" (50.8 mm) hole in the center of the plate would provide ~ 3 mm (0.125") clearance per side.
Assuming consistency in cases, that would mean that there is .35mm of clearance around that piston skirt when the 44mm is added. That’s around 14 thousands.
You don’t have to worry about adding too much case volume. You already have a mismatch there. I’d leave around .020 around that skirt, but that’s just for insurance in case the jug shifts a bit when you bolt it down. If you take too much you can cut through and render the case useless.
It gets tight there. You are effectively doing a hybrid, akin to an 044/046. Many times with the 044/046 hybrid one can have the same issue you are having if the base holes in the jug aren’t relieved correctly.
