Chainsaw Jim
Con Artist LLC
- 10:33 AM
- Feb 8, 2016
- Springfield Oregon
A chunk of radiator hose might also work.
I'd put some valve lapping compound on that flywheel and turn it on the crank. I bet it's not seating well. The key shouldn't be holding it in place.She ran today for me, idled and tuned good. Made two cuts and sheared off the flywheel key....doh.
Was cutting pretty sporty till then...
I'll order a gross of them tonight from HL, should be here before we leave in a week and a couple.
I've got some here if you don't find anything in time for the GTGI ordered a dozen keys last night on flea bay, will be the only real Stihl part, as HL Supply was out of stock. I will look around later for one from a taken apart saw to try and get going.
Going to be close, might have to file and install it in the motor home on the way there. Lol
Then make a few test cuts in the RV too?
I don't think so Tim.
Come on there has to be enough room for a cant stand.
I'll be happy just getting there and if a couple clunker saws run... that's OK too.
