Without reading each and every reply, here goes my theory
I bet you would notice a fair bit of carbon buildup on the transfers in a 262xp. As I mentioned in your other thread, many two strokes will back flow into the transfers before they ever flow up into the cylinder. Pressures are far greater in the upper cylinder after combustion than they are in the crankcase. This difference in pressures combined with a short period for blowdown tells me that Husky used the short blowdown period to increase crankcase pressure and ultimately charge velocity. Another thing to keep in mind here is that a shorter blowdown period will allow less time for fuel to escape out the exhaust.
With back flow the crankcase pressure will eventually exceed that of the upper half of the cylinder and the transfers will begin to flow fresh fuel up toward the combustion chamber. With the 262xp, the crankcase pressure will likely be lower than the cylinder pressure until somewhere near bottom dead center. This means that in 16-20° of crankshaft rotation, the piston will have trapped all of the fresh fuel above the exhaust port.
