- 11:10 PM
- Jan 22, 2022
- MO USA
Come on out to these woods and demonstrate, I'll pick u up at the airport I'm sure many a logger out here would like to see a magic cutI need to show you no fiber pull easterners the Magic Cut. ;-)
Careful what you say...I'd like to get to come cut with you. Years ago when I went to the NY GTG I was bummed I didn't get to meet you 'n @Spike60Come on out to these woods and demonstrate, I'll pick u up at the airport I'm sure many a logger out here would like to see a magic cut
( BTW to those who didn't catch it, the video is not about cut style & approach as much is it's about "tension & compression" and the shape of a hinge, doesn't matter if it's a bird mouth, conventional, Humboldt or some other wing bat concept. It's about getting a hinge to crush & get weaker before it goes to tension. And to get the fibers in a situation where they are more likely to break in your favor vs. pull out of the tree. I could do exactly the same demonstration with a Conventional , Humboldt western style cut, or any other with the hinge in the tree too. That face closes or a Dutchman or some other thing that puts those fibers in tension while in a configuration to pull.....it pulls Just that simple. )
Red Oak. 24” bar on 462. I normally don’t set the hinge in so far, but the root flare where I wanted my face cut determined different on this tree.
I’ve had it about 2 weeks now, and I’m getting used to it. It’s a lot more flexible than I was expecting. That being said, it’s also THE most forgiving bar I’ve ever used. You can just about turn it into a letter C and it’ll go right back straight - it’s very impressive that way. Weight is about what I was expecting for a “Light Weight” bar. It balances on the 462 very well. Wear has been minimal, if any. Overall, glad I bought it. @MG2186How are you likin that premium light bar?
All very true and have had the same experiencesThe thing I find is you can't be lazy with the power head. I see guys one handing and leaning back while plunging or face cutting, which is gonna stress the geometry. Totally acceptable for a soild bar ,but when I'm using a long light bar it's 2 hands and feet braced for balance .
Limbing is where I blow the chain the most.
How did he do that without getting the bar pinched? I did not see any wedgesThis guy's channel is really pretty cool, right after Bjarne Butler's I go here AND check out the "stumps" he's making
He left "spurs" or parts of the root flare. to hold it up until he was ready to let it go, hinge wood what little there is left alsoHow did he do that without getting the bar pinched? I did not see any wedges
Very similar to how Black Walnuts are cut.He left "spurs" or parts of the root flare. to hold it up until he was ready to let it go, hinge wood what little the is also
I would like a closer inspection. I saw no hinge wood. It looked like he cut the spurs off, except the last one, before boring into the tree. However he did it...it was pretty slick!!!He left "spurs" or parts of the root flare. to hold it up until he was ready to let it go, hinge wood what little the is also
