- 10:39 PM
- Jan 14, 2016
- North western Ohio
Here a site many don't know about ,very informative http://www.lathes.co.uk/
Well yes location has a lot to do with availability .This area during the late 80's was dubbed the "rust belt" because of the declining industrial base . Every say large factory supported several small "job shops " .When it went off shore the little guys just turned off the lights locked the door .
My advice if somebody is looking at a smaller lathe ,older ,take somebody with you who knows something about them if you don't .Then if you don't have the tooling you can get more money in that than you have in the machine so that's something to consider as well .They are out there you just have to find them .
Hello everyone I'm new to this forum and trying to learn where to post lol but to my question looking for input on a lathe specifically the
Grizzly G0768 https://www.grizzly.com/products/Grizzly-8-x-16-Variable-Speed-Benchtop-Lathe/G0768
looking at this lathe for machining the base and squish of chainsaws cylinder's
Thank you my friend. I didn't know and couldn't find a place dedicated to post about toolsWelcome aboard! You might consider starting a new thread. That way your question isn't lost in this thread.
Yeah, a point I pounded (mercilessly!) into the apprentices at work, was that the "Book" speeds and feed rates, are estimated to give a shop owner the best compromise between making money, and wearing out tooling and tools.
You can go a LOT slower, and much of the time what it gets you is done in more time, but very little in the way of severe wear on your cutters.
Slow is bad, if you are paying wages, electricity, a mortgage, and depreciation on the whole collection, but slower gives you as a beginner or non-production guy or gal, enough time to think. And to react, if things are moving the wrong direction!
Oh yeah. Learn to grind High Speed Steel tools! Cheap! Easy too! Practice will make it even easier! Angles are a lot less critical than you would think, as long as the edge is sharp. A tiny radius at the point is a help for durability too.
Carbide tooling is great if you have a bit of experience and confidence, but can become a very expensive source of a LOT of frustration as a beginner. At first, any wrong move will seemingly cost you a cutting edge off your tool.
There are a bunch of great tool grinding videos on youtube. I can recommend a fella called "This Old Tony" as worth watching, though I find his attempts at comedy a bit painful, as well as a fella by the moniker of "Clickspring".
I have 4 lathes, a shaper, a pantograph engraver, a manual mill and a cnc mill, as well as a whackload of tooling and other bits and pieces. Everything except enough floor space with adequate heat and lights <sigh>.
Yeah, it's a disease...
Just bolt the cylinder to an electric motor and hold some sandpaper to it, lol.I am currently in the market for a lathe looking for some advice on what I should get?
