Kawasaki FS481V Motor
S Sidwell
11:55 AM
Georgia
Do a little digging, I see this model doesn't carry an ignitor module, just two coils.
Steve, Samsung On5 using Tapatalk
11:55 AM
Thanks. I will clean the carb as a general maintenance issue to see if that solves it.
S Sidwell
11:55 AM
Georgia
These kawis are good motors
I've got two from the 80's, real good engines, a 9hp and a 12.5hp. I had removed the 9hp and and installed the 12.5 for more power in a JD RER. Just had to change out the wiring harness and build a relay harness for the starter motor. Safety switches had gotten where it wouldn't carry the voltage for the starter to work, but the switches still work.
11:55 AM
Thing that gets me is it ran fine for first 2 cuts. If this was the first time starting for the year, I could understand better. But it sputtered to a stop and won't run. Weird.
S Sidwell
11:55 AM
Georgia
Sounds like the Husqvarnas split boom brush cutters it went through in 2 months time. Coil went out on one with three hours use. 2nd one ran some what 30 minutes and died,(Carb issues and couldn't be adjusted out for it to run), the one I've got now has a hour on it so far.
S Sidwell
11:55 AM
Georgia
Should have bought a $60 Poulan.
11:55 AM
Lol. Or an Echo trimmer.
tickbitintn
10:55 AM
middle tn
Can't remember what engine it was (kohler or briggs) but it ran all crazy and intermittently and turned out to be magnets loose on flywheel...
Spark, fuel, compression... YUP!
Fourth thing is TIMED ignition.
Some"times" it was correct and would run properly.... Lol
11:55 AM
Lol. WTF. So maybe if I keep trying it will start up again?
tickbitintn
10:55 AM
middle tn
Sometimes it would start and run fine... Engage the blades.... Run like S... Major pain and very randomly would run properly..
11:55 AM
Well......... I fixed it. One of the dumbest things I have done.
I TURNED THE FUEL ON!!!!!
I got confusicated between on and off on the lever.
Thanks to everyone who tried to help my sorry azz.
tickbitintn
10:55 AM
middle tn
At least it's"fixed" !!
Lol
11:55 AM
Lol. Yup. I woke up out of a dead sleep this morning at 5am. Had an epiphany that it was the fuel shutoff valve. Engine started on first pull.
S Sidwell
11:55 AM
Georgia
Gas turned off [emoji44], you got to be kidding [emoji16][emoji1][emoji28][emoji23].
11:55 AM
Wow. You guys are tough. [emoji17]
I gave up team still a while ago. I am in a new forest now.
