Spike60
- 6:52 PM
- Feb 8, 2016
- Ulster County, NY
I have a Jonsered 2055 I am putting together so you put a sealant on the bearing cup like you would with the 2150?
That's correct. They just recommend silicone, and they show the Dow-Corning 3140 in the pic. I'd likely use the same Three Bond 1184 I use on everything.
EDIT: They also recommend doing it all at once. WM says to mount the cylinder and piston before the silicone has solidified, and then tighten it all up.
