Cerberus
Cerberus the aardvark, not the hell-hound!!
- 12:13 PM
- Jan 20, 2020
- Florida (tampa area)
tl;dr--- Is there some special 'class' of carbs for 2-stroke equipment? Am finding my polesaw, an old 'for-parts' pole-weedwhip, are using carbs that're throttling off a cable and can only be adjusted via the cable (IE doing an idle-speed adjustment) but NOTHING for H&L....I wanna, *gotta* , fatten/richen my mix if I'm going to mod the muff&airbox the way I want/the way I do on all my gear but if I can't alter fuel//air ratio on this carb I can't do much can I? :/ Thanks for any input, and I know - "throw it out, go buy lithium" - will have lithium soon enough and can then have this as-backup/rainy-day polesaw ;D
So I did a restoration project (snapped-in-half PPT-266, a $600MSRP echo polesaw...seemed a worthy challenge and certainly was!), however now that I've remedied its "real problems" and have done a few jobs with it I am just getting antsier&antsier to mod it (muffler mod for zero backpressure, airbox mod for more-than enough clean air availability) but there's no frickin' H&L screws!!!!!!!!)
Have never seen this, and have a weird "rule" that I won't get a strimmer/lawn-mower/edger/etc (afraid I'd "go that path" and only want trees / large shrub&topiary in my professional life, & lil bonsai when I get home ;D ), maybe it's a norm with shaft-driven equipment? I mean, the only possible input I can see myself having is adjustment of the throttle-cable's tautness (which can't even be 'turned-up' but just 'proper', so far as I can see)
BUT---- while I figured "must be those 'hidden carb screws' I've heard of", however since then I have seen 2 things that seriously worry me there:
1- I've studied it and cannot find anything (by-eye, or by viewing a schematic of this zama carb, an RB-K112), and WAY more-distressingly(since I've been treating the powerhead like any 'ole chainsaw-powerhead!), I just watched a video on usage(by Home Depot) and they're advocating that, on cold starts, after burping/turn-over while choked, that's fine, ***but***........They then say that, after normal turn-over/'burping' while it's choked, they say to un-choke and, before pulling that cord again, they ask you to **full-throttle** that trigger!!!!
2- I feel dumb saying it but I've just realized this engine does *not* have a fast-idle, which so far as I've seen is a universal/ubiquitous feature, kinda figured it was a requisite part of the start process, but this polesaw you simply pull it once to burp it, un-choke and pull a 2nd time and it begins purring, whether it was cold or just-used, it is the smoothest engine I've ever worked with (by a major margin and I have a new 355t..) but this no-fast-idle, and hearing a reco to start a cold-unit at full throttle (this is by Home Depot, in-context of using their rental polesaws, am gonna guess they proofed/edited that properly to prevent massive damages to all their polesaws lol!!)
Thanks a TON for any help here (is it possible/advisable to change carburetors here?? Would love a larger-jet carb in this thing), it runs a bit hot and while I removed the muffler's restricter-plate to try and help(and because I do a muff&air mod to every 2-stroke in my arsenal!) but both to increase efficiency/reduce heat *and* to increase total-power I really wanna be able to do my mods but if I can't richen my carb-settings then I'll run VERY lean and be playing roulette....ugh again thanks for any help, this thing has been one heck of a project and am so stoked that it's held its own through some jobs but not being able to adjust it is driving me nuts!!!
