usmcbuckwild
Buck
- 6:58 PM
- Dec 24, 2017
- NW CT
I have come across several threads with people having issues with the 268 (and other saws that use the same tank vent) being clogged/slow to vent. The tank vents are cheap enough, but if the saw is down; production has stopped. Rooting around in the shop I came up with a quick and free fix.
Remove the clogged tank vent (there are several how-tos on this already) separate the vent from the straw. Looking down in the vent you will see the “vent” material. Using a fine thread sheetrock screw, carefully thread the screw into the vent material and gently pull it out. If it breaks or disintegrates just fish the pieces out with a pick.
Grab one of the used plastic-foam type Husqvarna fuel filters. Remove the top plastic part that goes into the fuel line by cutting just below the plastic with a razor blade. This leaves you a hollow plasticy-foam thingy. Grab a 3/16” hollow punch or wood plug punch and knock a plug out of the bottom of the empty filter.
Grab the plug you just made and press it into the vent housing. Reinstall the straw and resinstall the entire vent assembly back into the saw. Start to finish: less than 5 minutes.
