Husqvarna 254XP Rebuild
7:56 PM
I am gonna run that piston because they are NLA and its not in bad shape. Slight carbon smear on the exhaust side but cleanable. Gonna get a ring, wrist pin bearing and run it.
Definitely would run that piston with a new ring. Just smooth it over with very fine grit sandpaper. I reused a 066 oem piston recently that had a few minor scuffs from ingesting something. I smoothed the high spots over and got new rings. Compression is great.
PA Dan
7:56 PM
White Oak PA
7:56 PM
Why are you replacing the wrist pin bearing? Is it bad?
Not a Husky pro, so I don’t know. Will a 262 P/C fit on that case and under that hood?
Johnmn
6:56 PM
Minnesota
It's very similar to a 262, 2mm shorter stroke though. I always wanted to try and put a 262 P/C on one.
XP_Slinger
They’re Just Saws
7:56 PM
Central NY
I always replace the wrist pin bearing on a rebuild, just because.
A 262 cylinder will bolt on but won’t fit under the cover. Would also need a crank from a 261/262 or 257.
