ZukiRyder400
Breaker of recoils
- 3:28 AM
- Apr 11, 2018
- Your bum
The crank is in awesome shape. Very very little play and the ring isn’t stuck.Stuck ring?
Looks like a nice little project. Hows the crank?
Thank you and I will get a video of it.Nice, i sure do like the looks of the 2 series. Looks like a little tiny 394
Good luck, would like to see it running when your done
Definitely would run that piston with a new ring. Just smooth it over with very fine grit sandpaper. I reused a 066 oem piston recently that had a few minor scuffs from ingesting something. I smoothed the high spots over and got new rings. Compression is great.I am gonna run that piston because they are NLA and its not in bad shape. Slight carbon smear on the exhaust side but cleanable. Gonna get a ring, wrist pin bearing and run it.
"Not gonna port it"...let me be the first to call you a liar! [emoji57]Rebuildin a 254 that I got for Christmas. Not gonna port it or anything, just doin the basic mods ( thinner gasket, timing advance, MM etc.). View attachment 274710 View attachment 274711 View attachment 274712 View attachment 274713
Lop! I promise I won’t."Not gonna port it"...let me be the first to call you a liar! [emoji57]
Thanks David.Lame!
I know a guy in ny that makes muffler deflectors in you need materials pm me I’ll give you his info.
It's very similar to a 262, 2mm shorter stroke though. I always wanted to try and put a 262 P/C on one.Why are you replacing the wrist pin bearing? Is it bad?
Not a Husky pro, so I don’t know. Will a 262 P/C fit on that case and under that hood?
It’s actually not a shorter stroke, it has a shorter connecting rodIt's very similar to a 262, 2mm shorter stroke though. I always wanted to try and put a 262 P/C on one.
I always replace the wrist pin bearing on a rebuild, just because.Why are you replacing the wrist pin bearing? Is it bad?
I always do get a new wrist pin bearing when I am rebuilding a saw. Just for extra assuranceWhy are you replacing the wrist pin bearing? Is it bad?
