JT78
- 4:43 AM
- Aug 29, 2016
- Burlington, nc
Well first one of these I've worked on. The owner broke off part of the crankshaft on the clutch side. He brought me the saw and I ordered a crank shaft from HLS well broke the saw down this evening and when I went to look at the new crankshaft it's completely different the OEM one had an actual flywheel key that was in the crank and the shaft was a different size on the flywheel side. So the flywheel will not fit the new shaft and the retaining nut for the flywheel on the OEM one is much larger. So I guess at this point my question is how do I get the crank, flywheel, retaining nut all together as I don't see them sold anywhere. Or how do I get a replacement original crankshaft for a fair price ?
