exSW
'Cause Thomas is a poopyhead
- 11:25 AM
- Dec 23, 2015
- United States
I can get the pads at Advance. I haven't seen those 3M balls anywhere.
Well the balls are convienient and you can find them ill look. Prob still expensive.I can get the pads at Advance. I haven't seen those 3M balls anywhere.
http://www.enginehones.com/abrasivehones.html I think this is a good site.I can get the pads at Advance. I haven't seen those 3M balls anywhere.
Double them up until its tightThat's what I'm talking about. I've used the disks and they don't have enough surface area against the cylinder wall. Those disks are thicker though.
Or use bigger pieces. Or both. What are you spinning them with?
Them things are able to be re built?I replace the ScotchBrite when it gets worn out......makes them much more affordable.
Did you see the extension for them in the link I posted is one needed?Yep.....they screw apart.
Here's what you need.
Not Me,
