There are several different ways I can set this carb up from this point.
One is for a mild saw that likely needs less fuel than what the stock jetting provided. These carbs are set up extremely rich from the factory.
For that situation, I plug the original jet before I reinstall it.
Next is for the saws I build for my customers. I leave the factory jet as it is. That means you can completely close off the HS circuit I created, and the saw will still start and run.......but it will be lean. You begin dialing it in by cracking the new HS jet open.....and fatten it up till it's just right.
Third.......I can make everything much bigger so the saw can run on Alky. That requires a bigger needle and seat.
