- 11:55 PM
- Dec 30, 2015
- Brewster, NY
It was a rainy day all day today, so I could not cut/split wood, etc, so I did another project.
One of my Asian 440 Big Bores was slated for some additional port work. The saw already has a used OEM 460 piston, and then a light went on in my head.
I have several of the HL Supply 460 Door Buster cylinders (they are still under $20). I used one on a 460 that did not have a cylinder, with a Meteor piston, and was very impressed with how it runs.
I've heard some folks have concerns with the plating, but mine seem to look good, so I'll use em and see how they hold up. The porting seems VG on these cylinders. I just cleaned up the ports a bit, added some small bridge ports, and lowered the intake to about 80.
To modify the cylinder for the hybrid build I had to slot the holes, and thin the left and right sides of the base (so it will fit the 440 case), but after that no other mods to the cylinder, no cutting of fins, etc, and I assembled it w/o a base gasket. Squish is .022.
You also have to remove some of the webbing in the front of the top cover. I used sheet metal shears and they seemed to work well for this. Of course, everyone is familiar with the muffler spacers. I did not have one, so I glued 3 washers to the muffler on each lower hole, and held them in place with vice grips. (PL Premium is my friend).
The only other interference was the top cover hit the cylinder where it bulges for the spark plug wire. Not wanting to mod either the cylinder or the top cover there, I just spaced out the lower left hole on the top cover. 4 washers and a small piece of flashing threaded on to hold them in place.
I also put some duct tape over the heat vent, as these saws do not come with the device to close them.
The rain stopped just about when I finished at about 5:00, so I got to fire it up and do one test cut with it. Feels strong, I'm happy with the way this "Budget saw" came out. Two more Hybrids in 5 days, I'm giddy!
And a big thanks to Dr Al for showing me how he did the other Hybrid. It made me feel comfortable about doing this one.
