- 11:29 AM
- Jan 14, 2016
- North western Ohio
I'm a little befuddled with this one .Belongs to the tree service that dropped the cotton wood .Danged thing won't built pressure and I suspect the control; valve .Somebody had the pressure set real low .I took it apart .looked okay and cranked it down to max ,no split .It won't even pull off detent on return .I saw the return line flex so I assume the pump is okay but I don't have a pressure gauge nor a tee fitting to install it .
I thought I had it once but I didn't .The machine looks brand new .At any rate I ordered a new valve through Surplus Center Hydraulics .Not bad $59 bucks ,Dirty Hand brand same as the OEM .It's either the valve or the pump .The cylinder is not bypassing .
