merc_man
merc_man
- 3:03 AM
- Feb 24, 2016
- southern ontario
Was working on a weedeater and couldnt get it to start. It would ever so slightly try on full choke and that was it.
Pulled carb blew out. Diaphram and pump looked good. Put the compression tester on after no luck after the carb clean and a different spark plug. Read just shy og 90 psi.
Im guessing its a little low. I know with the saws less then 130 is getting low so probly same rule of thumb for a weedeater too.
