Johnmn
- 12:45 PM
- Feb 18, 2016
- Minnesota
Just wanted to share some info with you guys about base gasket options.
I as the rest of you like to get the squish as close to .020 as possible. In the past if I can I have done base delete with a sealer, well recently I have pulled a couple cylinders that I have base deleted and the sealant wasn't stuck to the case or the cylinder. Well I didn't like that! So off Napa I went and I came home with a roll of gasket material that measures .0105! Which in most cases drops your cylinder .010-.020. it's easy to make your own, plus you can make a lot of base gaskets out of a roll. Just thought I'd share and maybe it's an option on your next build.
