Fruecrue
certified hand catcher
- 7:20 PM
- Jan 4, 2017
- Alden NY
Started assembly, most was pretty straight forward. I purchased a hyway gasket kit from HLSupply because I was concerned about the quality of the farmertec seals and case gasket.
I pulled the farmertec seals and chucked them. I then set the clutch side bearing a bit deeper to not interfere with the oil pump.
I heated some sae30 lawnmower oil in a metal can to 300 degrees, verified with a temperature probe.
I measured the width of the lobes and crankcase clearance to determine I needed .026" on either side.
I placed clutch side case over another metal can and poured hot oil over the bearing to heat it. Inserted crank using a feeler gage as spacer. Placed the gasket with a little motoseal then heated the second bearing and assembled the case with ease.
